sub and amp not working
  • Shmik
17 years 3 months ago #80093 by Shmik
sub and amp not working was created by Shmik
had a litle look and the power lead had come out, so put it back in but still not working :-/ checked all the other leads are in securely and they are. the fuse hasnt blown. the power light isnt coming on on the amp. dunno whats wrong! was working fine yesterday
17 years 3 months ago #80097 by Spence
Replied by Spence on topic sub and amp not working
Check ur remote wire to ur ignition/ head unit cause thats wat turns the amp on and with out that u get nothin
[img:1qvok2wf]http://i150.photobucket.com/albums/s101/seedoubleyou_bucket/Signatures/spence.jpg[/img:1qvok2wf]
  • Shmik
17 years 3 months ago #80098 by Shmik
Replied by Shmik on topic sub and amp not working
hmmm only problem is, i dont have the keys to get my head unit out. i was never given any when i bought it and chris used his ones when he fitted it all :S
would halfords charge me anything for them just to have a look at it?
17 years 3 months ago #80100 by Spence
Rite ok then thing to try is bridge i cable from ur 12v power input on the amp to the remote in put on ur amp ie the one next to it now that shoud chank to see if the problem is ur remote cable
17 years 3 months ago #80123 by Chris CW
Replied by Chris CW on topic sub and amp not working
Yeah as spence said just try and use a piece of wire (any really) to connect directly from the power (red cable) to the remote (blue cable - r) on the amp, this will atleast round it down to the remote to see if its the problem.
Could also be the fuse though, so pop the bonnet and have a look to see if the gold wavey piece is still intact - if not, the fuse has blown and you need a bigger one! (i dont know what size was in it tbh, but it should of been enough!)
17 years 3 months ago #80268 by starzoe
Replied by starzoe on topic sub and amp not working
I know the problem!! team p's crap wiring ;) lol joking! hope you get it sorted raver :D
[img:1rr7tmzk]http://offsite.warwickshiremodified.co.uk/signatures/starzoe.jpg[/img:1rr7tmzk]
[b:1rr7tmzk][color=#FF00BF:1rr7tmzk]*** Team Pink <3 ... YamYamYam... ***[/color:1rr7tmzk][/b:1rr7tmzk]
  • Shmik
17 years 3 months ago #80280 by Shmik
:P thnx, halfords said theyd take a look for a tenner
17 years 3 months ago #80282 by Chris CW
Nah look yourself Shmik, dont let Halfrauds con ya! You check the fuse?
  • Shmik
17 years 3 months ago #80290 by Shmik
yeh fuse is fine, the power had come out the amp but i put that back in!. i havnt got the keys to check if the lead has fallen out the back of the head unit! :( i tried to do it car thief style with some coat hangers but failed lol
17 years 3 months ago #80293 by Chris CW
If the power lead came out it might have touched the earth or amp casing etc, pull out the fuse in the amp and check that! The power lead was alittle short, I cut off as much as possible to use for the ground - only not to need it in the end anyway! Uber gay! Makes it awkward to check the wire goes in properley but you can whack the back seat down behind it and double check that way or just squeeze your head in the boot!
