sub and amp not working
17 years 3 months ago #80295 by slacker
Replied by slacker on topic sub and amp not working
i reckon chris put a timed fuse in so you have to come over again <!-- s:lol: --><img src="{SMILIES_PATH}/icon_lol.gif" alt=":lol:" title="Laughing" /><!-- s:lol: -->
  • Shmik
17 years 3 months ago #80298 by Shmik
Replied by Shmik on topic sub and amp not working
yeh i had the back seats down to look at it earlier.
how do i check the fuse on the amp? how do i tell if its broken?
[center:q0rsez8c][img:q0rsez8c]http&#58;//i165&#46;photobucket&#46;com/albums/u74/TayoDr00d/wmpurplesigsheep&#46;png[/img:q0rsez8c][/center:q0rsez8c]
&quot;Moo...*&quot;:q0rsez8c wrote: f**king ricer![/quote:q0rsez8c][/center:q0rsez8c]
17 years 3 months ago #80301 by Chris CW
Replied by Chris CW on topic sub and amp not working
Pull the fuse out, its right next to the power cable terminal. The two pins that come out of the plastic part of the fuse run inside and connect them both by a small piece of metal - just hold it up to the light and see if its still connected. If not, then buy another - not sure if you should go for something higher though, let me know what size it was
  • Shmik
17 years 3 months ago #80302 by Shmik
it says 30 on the top and i couldnt tell if it was conected in the middle, it looked black and melted inside? :S i took a pic but the quality is shit. will post now
17 years 3 months ago #80305 by Chris CW
Yeah if its melted inside thats it blown, there was a 40 in mine and it ran fine so buy or find a 40 to replace it - if you blow that one too your cranking it too much! May have to turn down the gain or super bass :D
You should have a spare fuse about, find your interior fusebox and one should be in there I think... any of the focus crew can shed some light on where it would be?
  • Shmik
17 years 3 months ago #80306 by Shmik
the power light isnt coming on on the amp btw. would that be because the fuse is blown?
17 years 3 months ago #80307 by readie si
Replied by readie si on topic sub and amp not working
two knives will take your head unit out if you ent got keys as spence says give the remote a check and change your fuse, fuse has probly blown due to a crap earth did you sand down the paint where your earth connects to the body??
17 years 3 months ago #80308 by Chris CW
The power light will only come on with your stereo, the remote lead is a small amount of power that tells the amp to turn on. If you used a piece of wire directly from the live cable to the remote this does the same job so you can see if it turns on - but you dont want to leave it like this as it will constantly be on then
  • Shmik
17 years 3 months ago #80309 by Shmik
is this it? :S
17 years 3 months ago #80311 by Chris CW
Ah could be, I dont see any spares though!
As Readie said though, just double check where the brown earth cable goes that its making contact with bear metal - didnt really check with the rush I was in :P
