*Update* Corsa struggling to move
15 years 6 months ago #161380
*Update* Corsa struggling to move was created by richie
Today this happened on the way home from work the car started playing up here are the symtoms
every time i stop it struggles to pull of unless i floor it
the revs at idle sit about 1000 then sometimes drop to about 250 and the engine almost cuts out
if i stay over 2000revs it seems ok
if i rev and stay constant at about 1200revs its pops bangs and back fires and i get popping from the air filter
ive changed all the spark plugs and checks levels and all seems ok
i loose power when i change gear to
any ideas?
its going to the garage tomorrow afternoon
any ideas?
- Sero
15 years 6 months ago #161384
by Sero
Replied by Sero on topic *Update* Corsa struggling to move
Low compression? Did you gap the new plugs? Head Gasket on its way out? Coil packs?
- george-wc
15 years 6 months ago #161385
by george-wc
[img:hik7p746]http://i932.photobucket.com/albums/ad169/georgewc4/untitled-3-1.jpg[/img:hik7p746]
Replied by george-wc on topic *Update* Corsa struggling to move
maf sensor
lambda sensor
idle air valve
check theese p.s i got a code reader
lambda sensor
idle air valve
15 years 6 months ago #161386
Replied by richie on topic *Update* Corsa struggling to move
Cheers guys, its on its way this afternoon to my cousins garage in nuneaton to get looked over.
As i get the work done on it a hell of alot cheaper
ill let you know what it is later on
- nibnob21
15 years 6 months ago #161393
by nibnob21
Replied by nibnob21 on topic *Update* Corsa struggling to move
I've started a thread on a Corsa forum I'm a part of to see what some of the members there think, I'll post back here as soon as anything useful is posted lol
- nibnob21
15 years 6 months ago #161394
by nibnob21
Just got this response straight away for you lol:
"The first thing i thoguht of when reading was idle control valve, but then i read the part about popping through the air filter. The only way this can happen is if the car is igniting the cylinder at the wrong time (when the inlet valve is open on said cylinder). I'd be looking at things like cam and crankshaft sensors.
Simple stuff first, make sure he's put the leads back on in the right order. Does the EML come on?"
- george-wc
15 years 6 months ago #161395
by george-wc
eml ? thats aways on in vauxhalls
- nibnob21
15 years 6 months ago #161396
by nibnob21
Haha not always, but using the old classic paper clip test it's always easy to diagnose what the problem is.
Doesn't work with the 1.2 16v or the 1.0 12v though.
To be honest, depending what engine you have they can vary from being problem after problem to being bullet proof. Luckily I have the X14SZ which if well looked after is the most simplistic easily maintained engines ever made
george-wc wrote: eml ? thats aways on in vauxhalls
15 years 6 months ago #161398
mines the x16xe
the EML isnt on cus i took the bulb out because of it keep coming on with the exhausts if i put a bulb back in guaranteed it will come on
- nibnob21
15 years 6 months ago #161400
by nibnob21
Well have you tried doing the paperclip test then?
Here's a link to the instructions for it if you don't know how to do it...
http://www.allcorsa.co.uk/forums/showth ... 26191.html
