Remote Turn on for amp
kingie07 wrote: yes if its gunna be a perminant install you will need hefty wires. i worked out that ti power mine effectivly i will need a 200watt psu. my mate has got a 400watt psu for me FREE lol gunna get it tonight.
Actually, Power = Current x Voltage...
So in your case Dr Hillmann, P(max) = 60(A) * 12(V) which is approximately 780 watts... which of course means you'll need a power supply capable of flowing at least 800W.
Now the problem you'll have is asking that power supply to deliver 60A - I suspect most PC PSU's have never seen that.
- kingie07
750W Continuous @ 40C (825W Peak)
Up to 90% (10dB) Less Noise per Watt
NVIDIA SLI Certified (Dual 8800 GTX)
80+ Certified (83%); .99 Active PFC
+12VDC @ 60A (Powerful Single Rail)
Rock-Solid, Super-Clean DC Output
24-pin, 8-pin*, 4-pin M/B Connectors
Quad PCI-E and 17 Drive Connectors
Automatic Fan Speed Control Circuit
5-Year Warranty and Tech Support
loving old skool physics. cant go wrong with itBluefox wrote: Actually, Power = Current x Voltage...
yes thinking that... all pc hardward going to be pretty low current i imagine...
although its a 60amp fuse on my power cable, and 2x30amp blade fuses on the amp itself. consider these are the ultimate top current allowed into the amp (over will blow the fuses
amp is Infinity Reference 7541akingie07 wrote: ok well... wat amp you got and what sub you got?
subs are Pioneer 12" ts-w306c (2 of them)
- kingie07
had it in my old car, had it in this... just cba with it. noise while im driving gets on my nerves and uses all my boot up
- kingie07
- kingie07
( i wounder i could marry it? hmmmm)
