Alloy Wheel ET/offset advice
13 years 6 months ago #176232 by M2UK
Alloy Wheel ET/offset advice was created by M2UK
Now then peeps, My Megane has an Alloy ET/Offset of 35 to 45, Now Im after some other Renault alloys with an ET/offset of 55, Is there any way of making them fit <!-- s:?: --><img src="{SMILIES_PATH}/icon_question.gif" alt=":?:" title="Question" /><!-- s:?: -->
Ta
13 years 6 months ago #176235 by nibnob21
Replied by nibnob21 on topic Alloy Wheel ET/offset advice
That's going to stick under the arch by another centimetre or so, so they may not fill the arches particularly well. And you'll run the risk of them scrubbing the inside of the wheel arch liner when turning sharply.
[url=http&#58;//www&#46;warwickshiremodified&#46;co&#46;uk/viewtopic&#46;php?f=20&amp;t=8222:2ok4lqln][color=#FF8000:2ok4lqln][b:2ok4lqln]MY PROJECT THREAD[/b:2ok4lqln][/color:2ok4lqln][/url:2ok4lqln]
13 years 6 months ago #176236 by lewys
Replied by lewys on topic Alloy Wheel ET/offset advice
they should be fine just get some spacers
13 years 6 months ago #176243 by M2UK
Replied by M2UK on topic Alloy Wheel ET/offset advice
Cheers chaps, Im not sure what to do now though, Does it mean that because there 55 offset and the meg takes 35 to 45 offset that they are more inside of the arch and if so do I need some 6 to 10mm spacers to make them fit right with longer bolts? The Meg does have quite big flared archs also.
13 years 6 months ago #176252 by lewys
I would say 10mm spacers with longer bolts. Make sure you get hub-centric spacers as well!
13 years 6 months ago #176253 by Andyfloss
Replied by Andyfloss on topic Alloy Wheel ET/offset advice
so if your car is say ET35 mate... and the wheels are ET55... 20mm spacers would make them ET35.... you can buy hubcentric spacers that bolt to your hub so you bolt the wheel to the spacer.
Higher the ET the further in the arch the lower the ET the more poke! :)
13 years 6 months ago #176259 by M2UK
Nice 1, Thanks Lads
