Forum
Motoring Sections
Wheels / Tyres / Suspension / Brakes
Suspension Knocking??
g0kph
Offline
Fresh WM User
Thank you received: 0
16 years 2 months ago #149174
by g0kph
Anyone got any ideas why on accelerating round left handers my Focus is knocking from the left like a goodun?? Also happens when acceleration over small bumps, ie tescos bridge warwick ??? And before you ask, i mean just normal accelerating not manic foot down rubber eating silly stuff !!! I've had it up in a garage and found one right (os) bottom ball joint US, which meant a total bottom arm replacement but its still the same?? I have been told that it could poss be the top strut mounts/bearings, but there aint no crunching at all from lock to lock and no play in the wheels !!! Helpppppp !!
16 years 2 months ago #149175
is ur car lowerd? mine knocks aswell (from the front) its cos the drop linkage has come loose. even if u tighten it, it will come loose again. it doesnt really matter tbh
[center:q0rsez8c]"Moo...*":q0rsez8c wrote: f**king ricer![/quote:q0rsez8c][/center:q0rsez8c]
g0kph
Offline
Fresh WM User
16 years 2 months ago #149178
by g0kph
nope not lowered yet, I did try changing the drop linkages, however had to give up as they are a barsteward to change as the nuts were as good as welded on and rounded as soon as i looked at em!! I will get em off, somehow !! as i've got two nice new ones sat in me boot waiting to be fitted !! I will keep u updated. Thanks for the help.
g0kph
Offline
Fresh WM User
16 years 2 months ago #149179
by g0kph
nutsplitter at the ready !!! Sounds painful dunnit lol
16 years 2 months ago #149182
mmm less likely to be the drop linkage being loose then if ur car aint lowerd. not sure sorry
16 years 2 months ago #149183
strut tops check the nut on the top to see if it has worked loose,
is it a rotational knock or just knock every now and again?
g0kph
Offline
Fresh WM User
16 years 2 months ago #149223
by g0kph
Only on bumps and cornering?? If I coast round a corner its fine or over a bump. It sounds like someones under there with a hammer and the wheel is loose, multiple knocking which can be felt thru the steering wheel? Bearings are fine, as are the track rod ends??
16 years 2 months ago #149231
by Craig H
Sounds fairly simple, check the usual, top mounts, drop links suspension bushes, ball joints ect ect
Former Honda Type R nut turned RS junkie
g0kph
Offline
Fresh WM User
g0kph
Offline
Fresh WM User
15 years 11 months ago #154168
by g0kph
There ya go, was the bloody driveshaft after all grrrrrrr
Forum
Motoring Sections
