Brake Not rubbing rust off disc?
  • slacker
  • Moderator
  • Moderator
16 years 9 months ago #116955 by slacker
Brake Not rubbing rust off disc? was created by slacker
Hi all,
Had to get some new pads on my focus the other week, now ive noticed the rust you get on the discs is not rubbing off when using the brakes. Theres an outer circle which the brakes don't seem to get.
To me this sounds like the brake pads are not the right size for the discs, but is this just because they need bedding in or should i be ringing the garage up?
Ta
16 years 9 months ago #116961 by jammy09
Replied by jammy09 on topic Brake Not rubbing rust off disc?
sounds quite normal to me to be honest , most cars were like that when i was in the trade
[img:2n91v8n7]http://offsite.warwickshiremodified.co.uk/signatures/jammy09.jpg[/img:2n91v8n7]
[color=#0000FF:2n91v8n7]^^^[/color:2n91v8n7]
[color=#FF0000:2n91v8n7]WORK IN PROGRESS[/color:2n91v8n7]
16 years 9 months ago #116963 by jammy09
actually how thick is this outter ring , if its no more than a few mill then its nothing to worry about
  • slacker
  • Moderator
  • Moderator
16 years 9 months ago #116965 by slacker
Replied by slacker on topic Brake Not rubbing rust off disc?
i'd say about 15mm-20mm defiantly wasn't like that on the old pads
16 years 9 months ago #116975 by jammy09
ahh right, yeah i would go back an make them double check there work
16 years 9 months ago #116976 by dr_hillmann
Replied by dr_hillmann on topic Brake Not rubbing rust off disc?
lol you didnt get these done at ettington garage did you before i take my car in there? :P
  • slacker
  • Moderator
  • Moderator
16 years 9 months ago #116977 by slacker
dr_hillmann wrote: lol you didnt get these done at ettington garage did you before i take my car in there? :P
no mate this was from EBT in stratty
16 years 9 months ago #117089 by readie si
Replied by readie si on topic Brake Not rubbing rust off disc?
does the car pull under braking? get on a straight get up to 45-50 slam the brakes on hard if you perform an emergency stop your cars fine and you'l probably find the corrosion has gone... however if you end up in a bush, you was braking because you seen a fox and sue the garage
16 years 9 months ago #117102 by preece59
Replied by preece59 on topic Brake Not rubbing rust off disc?
wrong pads
16 years 9 months ago #117118 by GhostWKD
Replied by GhostWKD on topic Brake Not rubbing rust off disc?
preece59 wrote: wrong pads
:yeahthat:
'91 R32 Skyline GTR <!-- s:) --><img src="{SMILIES_PATH}/icon_e_smile.gif" alt=":)" title="Smile" /><!-- s:) -->
