PCD Help On Alloy Wheels
  • lloydey--10
  • Banned
  • Banned
17 years 4 months ago #12271 by lloydey--10
PCD Help On Alloy Wheels was created by lloydey--10
Right
If You get a Car with a PCD of 4x100
Which My MG ZS is..
Can you get alloy wheels off another Make car.. for EG.
The BMW E30
because there PCD is the same.. 4x100
Ok yea the Bore is different.. But Surely if u got the right stud pattern which is the PCD... they will fit on???
Cannn Somee one Helpp mee pleasee
Becausee im lookin to Buy a set of AZEV alloys.. which ATM are on a E30 Cab... But there the same PCD as my car :) which is 4x100
Andd i wanna make sure they fit firsttt
17 years 4 months ago #12272 by Woody
Replied by Woody on topic PCD Help On Alloy Wheels
Yes you can, pretty much most will fit straight on some may require spiggot rings for the bore or spacers if the offset is compltely diffrent.
17 years 4 months ago #12302 by dr_hillmann
Replied by dr_hillmann on topic PCD Help On Alloy Wheels
offset will make the most difference, pcd doesnt particularly need to be the same, you could fit anythin in the range of 98-102 using wobbly bolts
if the centre bore is too big, you will need a hubcentric spacer... if bore is too small, you will need to get the centres milled out which is obvious ££
17 years 4 months ago #12329 by Turbo Ted
Replied by Turbo Ted on topic PCD Help On Alloy Wheels
the man speaks the truth^^^^^^^^,an e30 bmw is likely to have a larger offset on the rear wheels as they are rwd,the problem with the cantre bore is that the hubcentric spacers are around 70 quid for two,and often lead to increased tyre and bearing wear as it is pushing more load on them.
17 years 4 months ago #12371 by dr_hillmann
^^^^ yes yes, but on the other hand, you will be better off with hubcentric ones rather than plain flat ones, as the effects ed mentioned are worsend
17 years 4 months ago #12614 by Belmont Turbo
Replied by Belmont Turbo on topic PCD Help On Alloy Wheels
i would be more concerned about the offset tbh i think mg's are like et45 and bmw's are like et25 the bmw wheels will stick out to far and make it tram line like a bitch and you won't be able to lower it cus it will scrub.
spacers and wobbly bolts are a bodge! you should just buy wheels that fit
17 years 4 months ago #12786 by dr_hillmann
wobblies are a bit of a bodge. wouldnt say spacers are though. some cars have them fitted as standard...
