Jacking up issue
17 years 4 months ago #12027 by readie si
Replied by readie si on topic Jacking up issue
did u try lifting it up?? thought u might have a problem jacking it up cus of your body kit
if can get the jack under the chassis you'l be ok
by the way got a pump in the boot of my escort if u want to borrow it
  • QuBall
17 years 4 months ago #12030 by QuBall
Replied by QuBall on topic Jacking up issue
nah didnt try lifting it wouldnt want to try tho to be fair, yea it was the kit that was the issue, and the due course i measured im sat 4 inch of the floor which also didnt help,
ill let you know about the pump bud, i think we got one at work so if i forget to bring that home yea, is it one that goes in the cig lighter?
17 years 4 months ago #12031 by readie si
yer its electric if your gentle u can lift it up by the arches n get a mate to slide the jack under i used to work for silverline n thats how we would do it just make sure youve got the jack on somthing solid
being a fiat aswell jus take a bit of extra care when putting the wheel nuts in cus therte a bastard for cross threading
my numbers 07742840632 if u need that pump
17 years 4 months ago #12033 by pez
Replied by pez on topic Jacking up issue
with mine cuz the car is so low i use a scissor jack that you normally have in the boot to just get it up a bit b4 using the trolley jack...
17 years 4 months ago #12042 by retro dan
Replied by retro dan on topic Jacking up issue
lift the arches dude, mine are made of pure rust, and it's alright, you can lift the car off the ground though :neutral: haha, lift it then get a jack under!
  • QuBall
17 years 4 months ago #12056 by QuBall
nah i dont want to lift it,, weve sorted a way were going to do it now, but wont be till the weekend
17 years 4 months ago #12124 by slacker
Replied by slacker on topic Jacking up issue
Jacking up issue
Belt, tight, inject, sorted
17 years 4 months ago #12125 by sal
Replied by sal on topic Jacking up issue
pez wrote: with mine cuz the car is so low i use a scissor jack that you normally have in the boot to just get it up a bit b4 using the trolley jack...
exactly what i was gonna say...i need to do that at times too...but weirdly the two ton jack goes straight underneath!
