mk1 clio
  • mk1clioandy
14 years 3 months ago #166497 by mk1clioandy
mk1 clio was created by mk1clioandy
hey i am just wouding if i lower my mk1 clio would the camber go away
14 years 3 months ago #166506 by Vwpolodave
Replied by Vwpolodave on topic mk1 clio
Well it mite a lil bit but not a lot
EAT,SLEEP WM
  • mk1clioandy
14 years 3 months ago #166507 by mk1clioandy
Replied by mk1clioandy on topic mk1 clio
Vwpolodave wrote: Well it mite a lil bit but not a lot
cheers dude do u know how i can get it gone
14 years 3 months ago #166509 by Vwpolodave
It won't hurt it cus my cambers out a lil bit
EAT,SLEEP WM
14 years 3 months ago #166510 by Andyfloss
Replied by Andyfloss on topic mk1 clio
is it the fronts?
camber adjustable bolts? i dunno what the shock set up is like on a clio.
  • mk1clioandy
14 years 3 months ago #166513 by mk1clioandy
Vwpolodave wrote: It won't hurt it cus my cambers out a lil bit
its fucking the wheel bearing up
  • mk1clioandy
14 years 3 months ago #166514 by mk1clioandy
Andyfloss wrote: is it the fronts?
yer dude its top mout and two bolts atbottom
14 years 3 months ago #166516 by Vwpolodave
its f**king the wheel bearing up
Well fair play but some car r not bolted they are fixed of so u can't change them cus mine ls fixed but like Andy sed if der a bolt u just move it to left or rite but I don't no the set up as well
EAT,SLEEP WM
14 years 3 months ago #166522 by Andyfloss
right...
go on ebay type in camber adjustable bolts... then what you do ..
you have to bolts at the bottom...by the hub.... you loosen both of them and replace the top bolt with the new camber bolt....theres instructions with the bolt how to use it... but as the bolt turns it will push out/in the camber....get it to where you want it...(idid all the way out) then tighten the bolts off....SIMPLES
14 years 3 months ago #166523 by Andyfloss
