De-cat
- Zippy
13 years 2 months ago #174818
by Zippy
Replied by Zippy on topic De-cat
MIJ have had quite a bad name for a while now both among the modified car sites and from the manufacturer sites like skyline owners.
Best bet would be a powerflow garage, a decat is not much of a job so certainly should not be difficult for them which prevents it being bodged.
You'll find some slightly better response depending on your starting power, and that the car cruises at a steady speed easier. Don't expect too much from letting a bit more air out, you need more fuel to go quicker generally lol. Also before spending on a remap you want upgraded intake, exhaust and cams otherwise your paying a lot of money to gain bugger all.
- K50-DAN
13 years 2 months ago #174819
by K50-DAN
Replied by K50-DAN on topic De-cat
Custom chrome in Nuneaton, top guys, always had my exhausts done by them as I know them very well
The decat might bump your bhp up but then again you might lose it as mini cooper s's run better with a cat in, but then you don't have too worry about the cat breaking up and being sucked back in and also your exhaust temp will be slightly lower as the cat has to build upto temp for it too work efficiently (around 600 degrees if I recall) and your engine light will more then likely come on and mot will fail unless you know somewhere. But its better for noise (probably more raspy). You will probably notice slightly better throttle response as theres less restriction but a lot of it is physiologic due too more noise
- M2UK
- Thank you received: 1
- jdmcorolla
13 years 2 months ago #174877
by jdmcorolla
Replied by jdmcorolla on topic De-cat
Thanks guys, had this done and the results are better throttle response and a noticeable gain top end, more pops and bangs too
I also have put in bigger injectors, intake manifold and throttle body. It has a 4inch jap back box from MIJ which sounds pretty cool. I would like to map it but its very expensive for very little gains.
- Zippy
13 years 2 months ago #174879
by Zippy
You should probably have it remapped after having put in the larger injectors. As you can supposedly get more air in now and more fuel... so your likely not making decent use of the new parts.
- sonicvanman
13 years 2 months ago #174901
by sonicvanman
Replied by sonicvanman on topic De-cat
After having my exhaust off to fit my de-cat, i wouldnt recommend MIJ anymore, after examining it properly, the welding is shocking & the split for the dual pipes is to sudden & doesnt fit the single pipe properly & has just be filled with weld to fill the gap, a proper bodge job.
Me & my mate are having it back off tomorrow to sort it all out & add a small silencer as its proper loud.
- Felton
13 years 2 months ago #174904
by Felton
Replied by Felton on topic De-cat
Saw this going round by the recoH arena the other nite does sound really nice mate
- jdmcorolla
13 years 2 months ago #174905
by jdmcorolla
I have asked around for mapping but no one wants to touch it as the ecu is locked and is very hard to get into
if anyone knows anyone out who can do it give me a shout.
When was this Felton? Tuesday night by anychance?
And thanks mate
And thanks mate
- Felton
13 years 2 months ago #174906
by Felton
Yes buddy Tuesday or Wednesday I think carnt remember now lol I've seen u a few times round cov now and does look nice mate
- jdmcorolla
13 years 2 months ago #174907
by jdmcorolla
Thanks bud, a few times you say? Will have to keep an eye out for you
