HELP people!!
  • lewys
16 years 7 months ago #96765 by lewys
HELP people!! was created by lewys
Right found out the problem with my car, its the ecu!
so what do i need to do to fix it? how do i make sure i get the right ecu? then when i get the right ecu what else do i need to do?
How much is it all going to cost roughly aswell? (i.e. is it worth it)
16 years 7 months ago #96768 by Woody
Replied by Woody on topic HELP people!!
An ECU will only cost approx £30, with a little guidance im sure you could do it yourself. On your current ECU it should have the code or just google your model etc.
  • lewys
16 years 7 months ago #96846 by lewys
Replied by lewys on topic HELP people!!
thats the thing though, surely i need a different ecu, otherwise mine would have worked.
so how do i find out which one i need? do i need to get a code off the engine or what? and if so where is the code?
16 years 7 months ago #96847 by Turkish
Replied by Turkish on topic HELP people!!
I said 100% it would be the ECU :)
Speak to a Ford specialist of some sort, and just make sure you get an ECU that is the right compatability with that engine - you have to be precise otherwise it won't work. Worst case scenario is you need a special, gheyyy reconditioned one - like I had to have on the Cinq. Mine was £200 so I should imagine a common car like the Fez would be cheaper x
16 years 7 months ago #96940 by pez
Replied by pez on topic HELP people!!
should have a number on the block.. most cars do. this might help determine which ECU ya need..
16 years 7 months ago #97572 by PC
Replied by PC on topic HELP people!!
dude go down n ask for richie at kns tell him i sent ya (cough if he remebers me) lol explain ur problem n he'll sort u out!!!
in fine spirits like a dog on heat!!!!
