fule pump problem
- minge
16 years 8 months ago #91963
by minge
[color=#FF0000:iw8ojcjn]U LIV MORE IN 5 SECONDS FLAT OUT ON A BIKE THAN SUM PEOPLE DO IN A LYF TYM!!![/color:iw8ojcjn]
fule pump problem was created by minge
CAN ANY1 HELP!!!!!!!!!!! iv put the engine back in my ax all iz sweet apart from there iz no fule getting to the throttle body all the relays click as they should and the fule pump makes the noise but no fule????? n yes iv checked the fule n theres plenty i also went down the scrap yard n bought anufa 1 and tested it be4 i took it out got it back n nada jus the same any ideaz!!!!!!!!!!!!!!
- pez
16 years 8 months ago #91967
by pez
Replied by pez on topic fule pump problem
fuel pipe blockage? fuel filter blockage? injectors working?
- PC
16 years 8 months ago #91987
by PC
in fine spirits like a dog on heat!!!!
Replied by PC on topic fule pump problem
make ure the fuel pump is actually pumping fuel out of it!!! if its not coming out the end of the pump it wont reach the injectors!!! it will make a noise even if not working!!!
16 years 8 months ago #92011
Replied by Turbo Ted on topic fule pump problem
is it wored in the right way??sorry to sound patronising but it could be running backwards if you have had it all apart
- minge
16 years 8 months ago #92065
by minge
Replied by minge on topic fule pump problem
theres no block in pipe as i took da pipes off the pump n still no good n i was thinkin that but i swaped the wires round n it didnt work atall n iv took the filter off comleatly n still no joy
thanks anywayz
- PC
16 years 8 months ago #92074
by PC
is there fuel coming directly from the pump, in the direction of the feed up the the engine bay? to be fair mate it starting to sound like the pump mite be at fault cos if the unit is worn then it will create any pressure to feed the fuel through!!!
- kno88y
16 years 8 months ago #92183
by kno88y
Replied by kno88y on topic fule pump problem
have you primmed the pump ie put fuel init first ive come across pumps in all kinds of applications that need priming to work first other wise it just sucks air, does it heat up loads when running if so its not pumping fuel just air, does fuel come from the tank, ie come out of the hose when not hooked up to the pump, take all pipes off and blow down them for blockages, not a grease monkey by trade but using what i would do in a situation
