changing engine from 1.4 to 1.6 on VW Bora
- Zimbabwe76
- poulton1987
- C.K
that would be mint
[img:yby4hm11]http://i932.photobucket.com/albums/ad169/georgewc4/62492_1458333612839_1068348516_31093335_7967512_n-1.jpg[/img:yby4hm11]
[b:yby4hm11]slam it thats my answer[/b:yby4hm11]
Zimbabwe76 wrote: I need to know whether its possible to change 1.4 liter to 1.6 on a 2004 VW BORA....what are the requirements....any help?
It's not worth it IMHO. The work involved would be too much. If you're going to do an engine transplant into a Bora, it'd have to be something silly like the 3.0 TDI already mentioned or a R32 engine or something.
There's a reason people tend not to do engine transplants on Boras.
- Davez-R
have a look at ur other options, such as the 1.8t very tunable and quiiiiick !
- DuB_SC3NE
1.4 is a underpowered lump that drinks fuel with 75bhp, tbh it's one of the worst engines vw produced, even the polo 1.4 had a 100bhp and also has a shoddy gearbox and gearbox in the 1.6 is even worse. I would upgrade to the 1.8 lump if you want normally aspirated with 125bhp. The 2.0 engine is also a weak engine.
Depends on what you want out of you're bora, daily commuter or some power.
- Davez-R
- DuB_SC3NE
engine + ancillaries
turbo + manifold + all associated oil/ water feeds and charge / boost pipes + tip
gearbox
driveshafts
hubs + brakes
downpipe + cat + both lambda's
maf and airbox
full front engine loom
ecu + clocks + key - ecu can be de-transpondered to allow it to work with your key+ clocks
all water pipes
fuse carrier on top of battery
starter motor
all engine mounts (to be on the safe side) only gearbox mount is needed
cat back exhaust sytem
front struts
p/s pipes
intercooler
Best of buying a slavage car like i am, keeps cost down and can recoup money by selling parts you don't use.
- DuB_SC3NE
