ENGINE LIGHT IS ON ( HELP )!!!!!!!!!!
17 years 8 months ago #28710 by Ryan.James
Replied by Ryan.James on topic ENGINE LIGHT IS ON ( HELP )!!!!!!!!!!
I think corsa's are prone to this dude, mine had the same fault but all my clocks would die aswel, it would still drive normal with no problems its just my clock would all drop down as if the engine wasnt on. But as others have said i cant see it being you air flow meter as this would make it lumpy and it would try and cut out at idle.
[img:p086e0lo]http://i171.photobucket.com/albums/u317/ryanjames900/Newsig.jpg[/img:p086e0lo]
17 years 8 months ago #28714 by Dannii
Replied by Dannii on topic ENGINE LIGHT IS ON ( HELP )!!!!!!!!!!
yeahhh i have tha.. but my clock connections broke.. so they cum lose.. even if i push um back in i have to bang um to make up work otherwise i crnt indicate..
but... if my clocks go off my car wont start either so have to bang um an tha try start it again!!
yeahh i think lotsa corsa have the same problems! xx
[center:1yttga2v][img:1yttga2v]http://i331.photobucket.com/albums/l471/D19NY-X/meesig.jpg[/img:1yttga2v][/center:1yttga2v]
  • pudnoka
17 years 8 months ago #28723 by pudnoka
Replied by pudnoka on topic ENGINE LIGHT IS ON ( HELP )!!!!!!!!!!
thanks
ill have it checked it out cuz thats the 1st time sum ppl have mentioned the crank sensor
17 years 8 months ago #28726 by Dannii
no probs.. hope ya get it sortedd xx
  • pudnoka
17 years 8 months ago #28743 by pudnoka
thanks princess xx
17 years 8 months ago #28806 by retro dan
Replied by retro dan on topic ENGINE LIGHT IS ON ( HELP )!!!!!!!!!!
Give it a full service for peice of mind, clean out all the intake mani aswell, my engine light came on, i chaged coil and took intake all off, it was restricting a minute bit of air going in, but still ran fine, when i cleaned it no light :)
17 years 8 months ago #29125 by dr_hillmann
Replied by dr_hillmann on topic ENGINE LIGHT IS ON ( HELP )!!!!!!!!!!
my housemates corsa has the engine light on. he just ignores it and carries on and its been fine
17 years 8 months ago #29151 by Belmont Turbo
Replied by Belmont Turbo on topic ENGINE LIGHT IS ON ( HELP )!!!!!!!!!!
i would change the CTS (coolent temp sensor) first as they can cause all sorts of weird problems and their a common fault on all vauxhalls. there one of the cheapest sensors to so a good place to start
17 years 8 months ago #29179 by Mattie
Replied by Mattie on topic ENGINE LIGHT IS ON ( HELP )!!!!!!!!!!
put a bit of black tape over the light?? wont see it then
17 years 7 months ago #30163 by readie si
Replied by readie si on topic ENGINE LIGHT IS ON ( HELP )!!!!!!!!!!
its an m reg corsa? there prone to this i bet u spend ages lookin for a problem wen really its probly somthin stupid as a loose wire
personally i would ignore it sounds silly but it probly is just the light stayin on my mrs had an L reg corsa with the same fault, and ive seen plenty with the same head scratchin problem, turned out a bit of electric kept gettin to the l.e.d on the dash makin it turn on n off for no reason
corsas are a simple engine mechanically if a mechanic cant find a problem with it i would leave it. if its really buggin u take the facia off the dash n remove the wire to the light on the back of it
