help plz
  • Andy
16 years 2 weeks ago #144854 by Andy
help plz was created by Andy
need to use this but not sure how to set it up right so i can tell what the correct volts are.... ;)
also has u can see 3 holes down the right had side which i got the leads for but not sure were to plug the black/red leads in......
16 years 2 weeks ago #144855 by kingie07
Replied by kingie07 on topic help plz
put red to pos of bat and black on earth Done... lol
  • Andy
16 years 2 weeks ago #144856 by Andy
Replied by Andy on topic help plz
yeah i know that but not sure which one to set the arrow to has their is different ones on the panel
16 years 2 weeks ago #144857 by kingie07
i think its 10A then top and bottom holes but not sure so dont take my answer :D
  • Andy
16 years 2 weeks ago #144858 by Andy
16 years 2 weeks ago #144860 by richard1987
Replied by richard1987 on topic help plz
im not being funny if you downt know how to set it up how do you know what your checking???
[img:19d7u4r4]http://offsite.warwickshiremodified.co.uk/signatures/richard1987v3.jpg[/img:19d7u4r4]
loves the r33 GTR
  • Andy
16 years 2 weeks ago #144865 by Andy
richard1987 wrote: im not being funny if you downt know how to set it up how do you know what your checking???
i just want to use for ie check,how many volts in powercap/or 12v lead some were i could use
16 years 2 weeks ago #144892 by richie
Replied by richie on topic help plz
i do electrical installation at work and ill be a qualified electrician in a few weeks just a quick note if you set the meter up wrong and measure in amps instead of voltage for example you can actually blow the meter up and it can cause serious injury so be careful car batterys are DC right so you would set it on (dcv 20) as car batterys are only 12-15v
16 years 2 weeks ago #144897 by Richard109
Replied by Richard109 on topic help plz
the positive goes in to the 10v (top hole) the negative in to the bottom hole, turn the dial from the off position backwards to the section DCV 20 - this will allow u to measure the voltage you require - to test it and not damage the multimeter use a aa battery and as u know u should get 1.5 on the display.
When u put it on to the capacitor if u get a 1 symbol this means it out of measuring range therefor turn it up to 200. this should not be the case. and you should get a reading of 12v or what your trying to measure.
Why do u want to check this - are u having problems wih it working? - are u trying to install it in to a present system you have?
  • Andy
16 years 2 weeks ago #144902 by Andy
Richard109 wrote: the positive goes in to the 10v (top hole) the negative in to the bottom hole, turn the dial from the off position backwards to the section DCV 20 - this will allow u to measure the voltage you require - to test it and not damage the multimeter use a aa battery and as u know u should get 1.5 on the display.
i forgot that i had this and was trying to work out how to use it ;)
