dial help
- paulcwn
17 years 2 months ago #91531
by paulcwn
dial help was created by paulcwn
just had another look at my faulty dials that work when they want.
They work as soon as you get into it but if i switch ignition off and back on they stop working and re-work when they feel like it !!! cant find anything wrong with the connections and when i take the negative cable off the battery and re fit they work has anyone got any ideas to help me please ??
it is a punto mk 2 it seems to play up more when stereo is on
- pez
17 years 2 months ago #91612
by pez
Replied by pez on topic dial help
could be the wires are taped closely together and when a surge of power is put through to radio or somewhere else its jumping between wires... if there is a split in the plastic case on the wire this may be the cause..
- PC
17 years 2 months ago #91993
by PC
in fine spirits like a dog on heat!!!!
Replied by PC on topic dial help
sounds like a faulty clock set!! the boards break in the back, go get one from the scrappy n try that in there!!! u mite find it'll work mint!
