Why Not To Have 6X9's
- slacker
- Moderator
DO NOT put speakers in the back (especially 6x9's they are usually designed to play loud but sacrifice quality for harsh treble)
Music coming from behind you only muddies sound
think about it....
do you goto a gig and stand with your back to the band? nope!
are your ears facing forward for a reason? yup!
a good pair of amped component speakers up front will do you
if you sometimes have people in the back then by all means uprate the speakers in the rear panels but have them running of the head unit amp and fade them out if no one is in the back.
you will be amazed at how good just a pair of componets up front with a good amount of power will sound.
as for subs in the boot and 6 x 9's you will kill the 6x9's the sub will be pounding the same air as the 6x9s and eventually they will die. take the 6x9's out re cover the shelf so the holes for the 6x9s let bass into the cabin
So - in summary
Dont have speakers in the back unless you take people regularly - if you must have speakers in the back run the off the head unit but fade them forward if noone is in the back
remove the 6x9's and recover the shelf this will let bass into the cabin
get a good 2 channel amp for your front speakers
ok, they were Rainbow 5x7s, so not cheap and nasty crap, but I think maybe some comps would both sound AND look better - live and learn eh!
- slacker
- Moderator
- mikeyjp
my 6x9's are crap but have to put up with them until i can afford something else lol
- Tazzy
we all know 6x9s arent the best, but its what is out there on offer, and i could hazard a guess and say i reckon most modifyed cars will have a set of 6x9s int he rear, they are just cheap and easy to use
i also agree with chris that 6x9 technology has improved, its had to!
until the tech heads create a 6x9 to create perfect sound from all 3 speakers, we will just have to make do with what weve got!...
[color=#FF0000:e3yh0o2g]If It Comes Off, Modify It![/color:e3yh0o2g]
[color=#0080FF:e3yh0o2g]Cruise-Mids - [i:e3yh0o2g]The Cars, The People, The Scene![/i:e3yh0o2g][/color:e3yh0o2g]
