Fiesta Mk6 - 12v interior neon fitting
last time i powered them off my amp terminals for the 12v, which was easy enough, but this time i want them from somewhere else, as i want light when the amp isnt in the car!
any ideas...
(and im not gonna use a plug for the lighter soocket, cos i need that for other bits)
is there somewhere else good to get a feed from??
cheers
- Dave_P
- Banned
- Dave_P
- Banned
Sara wrote: be permantly on thou! they will be on with sidelights with the heater route
ill try find something with a permanent feed, so i can switch them separately
Sara wrote: can copy the whole thing if needed tis got footwell lighting, puddle lights etc
http://www.ukfiestanetwork.com/index.ph ... 132191&hl=
cheers for this
what voltage is in the headunit power block does anyone know??
as i have an aftermarket headunit in... and have a blanking panel i can get to those wires really easy...
- ben_zetecs
- Thank you received: 1
what about the boot light ?? and run switch off that ??
[img:3m2bfus0]http://i195.photobucket.com/albums/z129/ben_106/Ben-ZetecS-Sig-New.gif[/img:3m2bfus0]
just not decided wether to put 2 tubes each side or 1...
2 each side would be easier, as they are wired in pairs...
