AMP protected - help ??????
17 years 2 months ago #30436
by Gritz
AMP protected - help ?????? was created by Gritz
i wired all mi sub and amp up but on the amp there a red light n it ses protected and when i earth it , it goes off when its ment to turn green so it works,, the amps defo getting power cus the lights on the onl thing i fink it cud is the remote lead theres a blue remoted lead coming off the stereo and there 1 thats on the back of the harness thing with do i connect the lead to ?
- jpmilling
17 years 2 months ago #30437
by jpmilling
<!-- m --><a class="postlink" href=" www.zero260.co.uk/forum/index.php?topic=2506.0 "> www.zero260.co.uk/forum/index.php?topic=2506.0 </a><!-- m -->
Replied by jpmilling on topic AMP protected - help ??????
hi mate,
you should have 3 wires to power the amp.
red live for battery
black earth for somewhere grounded in boot
blue wire remote which connects to the back of your stereo headunit.
when all connected the amp should come on and off the same time as your stereo.
- slacker
- Moderator
17 years 2 months ago #30444
by slacker
Replied by slacker on topic AMP protected - help ??????
If your having problems, might be the grounding point, are you connecting it to painted metal? If so it's best to sand it down to bare metal.
17 years 2 months ago #30450
Replied by Chris CW on topic AMP protected - help ??????
With the remote lead you can connect it to the back of the headunit on the blue remote lead you mentioned, or the yellow wire (ignition)
17 years 2 months ago #30452
Replied by Woody on topic AMP protected - help ??????
Yeah sounds as though the remote lead isnt working.
17 years 2 months ago #30455
by Gritz
Replied by Gritz on topic AMP protected - help ??????
dose n e body fancy avin a go 4 me i hate wires hahahahahahaha
17 years 2 months ago #30460
by Gritz
i will take sum pic 2 moz 4 u boys 2 c if i have wierd the remote rong , soound
17 years 2 months ago #30572
Replied by Turbo Ted on topic AMP protected - help ??????
its pretty simple,there should be a small blue wire in the rear of the stereo,extend this with wire to the amp and it should fire up,the remote lead sends a 5v live down the remote lead to tell the amp that it has a source,which it should then turn on and power up
17 years 2 months ago #30575
Replied by dr_hillmann on topic AMP protected - help ??????
what JP said, but quality of earth will be a major factor
17 years 2 months ago #30603
by Gritz
theres a wire cumin off the head unit sayin amp and its blue thats the 1 i have been wire'in it to , im earthing it to a bolt on the bk of the car , bt when i earth the protect light goes off
