I.C.E Setup!
18 years 4 weeks ago #820
I.C.E Setup! was created by Bee
would this be a good setup for quality sounds rather then bass and loudness,
tweeters in the a pillars
5in speakers in the door cards
5in in the rear parcel shelf
possible small amp aswell
anything else i need?
18 years 4 weeks ago #821
Replied by Bee on topic I.C.E Setup!
also does the tye of wire i use affect the quality of sound produced?
18 years 4 weeks ago #822
Replied by Chris CW on topic I.C.E Setup!
If you have alot of amps etc then yeah the power cable will matter, you'll want 0G wire, but what your looking at I think you'll be OK at the normal stuff (4,
. What youve listed will be good for clarity, just make it a mix of component 5" and 3-way coaxials then some decent tweeters.
18 years 4 weeks ago #823
wheres the best place to mount the speakres aswell
so get a combination of different sized speakers to provide different ranges?
18 years 4 weeks ago #824
you dont have to go with different sizes, just different types imo, the coaxials have the tweeters built in and are normally 3 way, so the mid-range and then 2 types of tweeter built into the centre stem. Then component speakers have full on mid-range with a independent/seperate tweeter - both have their advantages and disadvantages
As for positioning, first off the standard speakers just upgrade them, so its neat, not in the way at all, and solid, then maybe experiment abit, keeping them high and out of the way again, mid-range and bass travels pretty well low as the vibrations are used against the car bodywork aswell, whereas treble struggles to travel in the same way so thats why pillars are a good option (and their small enough of course)
- Tazzy
18 years 1 week ago #2456
by Tazzy
[color=#FF0000:e3yh0o2g]If It Comes Off, Modify It![/color:e3yh0o2g]
[color=#0080FF:e3yh0o2g]Cruise-Mids - [i:e3yh0o2g]The Cars, The People, The Scene![/i:e3yh0o2g][/color:e3yh0o2g]
Replied by Tazzy on topic I.C.E Setup!
components are so much better than coaxials as the sound is problem up by the crossover, coaxials are like you playing football, knitting and eating a macdonalds at the same time
ive got a set of coaxials from a decent manufacturer and theyre already distorting!
17 years 9 months ago #9695
Replied by dr_hillmann on topic I.C.E Setup!
i had some 3 way JBL coaxs, but they were amped with a low/flat signal, and they did a pretty good job at adding a bit more punch and volume. i had other speakers up front for most of the volume and treble
