induction kits
- ward19
16 years 2 days ago #138956
by ward19
induction kits was created by ward19
hey im a right novice at moding and jw what the hoses are that come from your engine to like an external point of your car. i kno its for air intake but where do i get 1 and how do i fit it. would love loadsa info and ideas thanks wm, adam
16 years 2 days ago #138957
Replied by Vlad on topic induction kits
well, if u get an aftermarker induction kit- ull hav to take ur original air filter/box out and connect inducstion kit....once u get induction kit-u will see str8 away where to put it...and they usually come with instruction anyway. easy job.
- ward19
16 years 18 hours ago #139183
by ward19
Replied by ward19 on topic induction kits
where would i get 1 from and would it b easy to fit asin id do itbit o a novice?
16 years 16 hours ago #139188
Replied by MonsterMatt on topic induction kits
Halfords, Demon Tweeks or from K&N or Pipercross or something... Just Google it..?
16 years 12 hours ago #139193
<!-- w -->
www.demon-tweeks.co.uk
<!-- w -->
<!-- w --> www.potn.co.uk <!-- w -->
<!-- w --> www.stxstyling.co.uk <!-- w --> and maaaaaaany more or yea as Matt said u can get them directly from companies that make them like pipercross,k&n n so on or just type in " car modifying" in google
- ward19
15 years 11 months ago #139268
by ward19
ta forall your help. id love to come to 1 of your meets and see ya cars n stuff but i think mine aint to good tbh and think id look like a right tit
15 years 10 months ago #144135
by Bluefox
- si-george
- Visitor
15 years 10 months ago #144166
by si-george
Replied by si-george on topic induction kits
- ward19
15 years 10 months ago #144246
by ward19
that loooks sick
- AndyBuck
15 years 10 months ago #144252
by AndyBuck
[url=http://andybuckr25.blogspot.com:35cgzg50][img:35cgzg50]http://img695.imageshack.us/img695/7272/themgzrsig500px.jpg[/img:35cgzg50][/url:35cgzg50]
[url=http://mgroverservice.blogspot.com/:35cgzg50][b:35cgzg50] MG Rover 25/ZR Service and How-To Guides[/b:35cgzg50][/url:35cgzg50]
Replied by AndyBuck on topic induction kits
You want an enclosed airfilter, not an open cone. Open cones experience heat soak (explained later)
ITG Maxogen - £300ish,
BMC CDA - £180ish,
Apiro DIAVOLO - £80ish,
Pipercross viper - £180ish.
Any of those, I assume its for your ZR?
The tubing that goes to an external point is called a Cold air feed (CAF) on a ZR you want to run it straight through between the frame and the radiator. It's a bit of a squeeze but it avoids running it over the manifold, which would make it suffer heat soak. Heat soak is where the induction air is heated causing the air to expand, thus you get less density of air per stroke in the engine = less power. You want the induction air to be as cold as you can, hence the COLD air feed.
And it also avoids cutting a hole in the frame to run it through to below the headlight.
You would then cut a hole in the bottom mesh and mount the funnel end of it to that.
I suspect you wont want to pay that much, so the next best option is to buy a pipercross or K&N panel filter (just a performance version of the filter you already have) and that will cost about £30.
BMC CDA - £180ish,
