help please! exhaust manifold.....
do not quote this bit as im not 100% i know the puma is based on the fiesta so the manifold from a puma should in theory be a direct fit to the fiesta's system best bet is have a trawl through the passion ford tech guides and look for similar projects, some of the biggest names in the ford scene post on passion ford so any advice you get off there will be the best you can get
- lewys
- mini-mole
also with the racing puma exhaust it will fit on to your exhaust (may have to trim a small piece off if your going to go down the cat route, as the cat sits on the underside of the car and not as a manicat, so there are de-cat pipes available so its just a case of simply unbolting the cat and swapping it when it comes to mot time.
hope this helps
readie si wrote: .
lol soz had to b dun
I'd say Readie's advice is pretty comprahensive.
