Help, Stalling Problems
16 years 8 months ago #95490 by PC
Replied by PC on topic Help, Stalling Problems
has it got the plastic manifold??? check the vacuum pipe on the corner of the head!! c if thats split!! or idle control valve under the manifold!!!
in fine spirits like a dog on heat!!!!
16 years 8 months ago #95496 by readie si
Replied by readie si on topic Help, Stalling Problems
it will be the breather pipe under the throttle bodie mine did the same take it to K&S in cov rich will sort you out, or bring it over to me i'll have a look if you dont know what your doing ;)
  • bushanab
16 years 8 months ago #95714 by bushanab
Replied by bushanab on topic Help, Stalling Problems
readie si wrote: it will be the breather pipe under the throttle bodie mine did the same take it to K&S in cov rich will sort you out, or bring it over to me i'll have a look if you dont know what your doing ;)
thanks i took it to rowleys in leamington cause i needed to go there anyway hes a family friend and he did wot u just sed and now its been working fine at low revs
