Speakers
It you get an 'active' subwoofer the amp will already be built in to suit it
- Bruno Henriques
Chris CW wrote: You'll only need 2 channel for one sub (L & R, or - & + per speaker), a 1000w sub will most likely be around 500w rms but I would still get a 1000w amp to match, or even higher if you watch the gain settings on the amp and dont mind shortening the lifespan of the sub. If you mean wiring, again I would match the max figures so theres no chance of resistance
i only see the Edge EDB12 12" Active Subwoofer 900w, in halfords , you now any more sub with the amp built in??
- Bruno Henriques
Juice JA590 Key Features
•1200 Watts 2 Channel Amplifier
•Bridgeable
•High level speaker input
•Pulse Width Modulated (PWM) MOSFET Power Supply
•Variable input sensitivity; RCA input 0.2V to 6V
•Thermal, Overload and Short circuit protection
•Excellent muting circuitry prevents turn on/off ‘pops’
•Built-in High Pass / Full Range / Low Pass Filter switch
•Silver plated power connectors for optimum power distribution
•Silver plated speaker connectors for optimum signal output
•10" Subwoofer in 4th Order Enclosure
•Driver: In Phase XT 10
•Power: 1200W
•Bass aero dynamic port: 1
•Linear Aero Venting
•Double Spider
•Flush Fitted
•Crakle Paint Effect
•Frequency Response: 35-300Hz
•Sensitivity: 95dB
•Impedance: 4ohms
•Height: 410mm
•Width: 420mm
•Depth: 285mm
This amp its ok for the sub or not?? and if later i want to change the speakers this amp its ok for everthing??
and the edge is good because of the space and the amp is built in built in.
- Bruno Henriques
Andyfloss wrote: get a vibe CBR active sub if you can..best thing youll buy
its good??
you say this
http://cgi.ebay.co.uk/Vibe-CBR10-EVO-AC ... 3cb2e40a90
- Bruno Henriques
Andyfloss wrote: yes there awsome in terms of sound quality.. its kevlar so its a really nice sound.. my brother was selling his its like brand new.. ill see how much he wants
ok
- millz
the sound quality from the standard speakers is pretty good
- Bruno Henriques
millz wrote: tbh mate the 207 stereo isnt that bad i would just add a sub.
for now i only going put the sub, but i dont now witch i gonna put
- Bruno Henriques
I choose to fit the vibe now waiting for the sub arrive, i buy in the website caraudiosecurity, and after look for someone to fit
Thanks
